void777
ruffdog
You are correct but most other componets will stick rings,crank oil pump cheap insurance.
I re-read the op to see if the hours were mentioned. 250 and she doesn't think the filter (and oil?) have ever been changed.
Does Kubota not use break-in oil? Just curious. Funny, I always assumed that oil was higher quality, and it's not, being designed to wear-in parts.
I have to add something, I used Kubota 15w-40 engine oil to do this oil change but lost most of it down the drain. The last pint I put was whatever left from that gallon jug. And then the 3 quarts that I added last was also 15W-40 but Walmart brand or something but good for diesel and gasoline. Is this considered mixing oil?
Everyone is overlooking that the OP, a wife, tried to change the oil in the tractor. That earns a lot of points in my book. Not too many wives would even attempt to do that.
Kudos to you OP.
Kudos to you OP.
Thank you! I’m actually glad I learned something new eventhough this could cost so much due to my carelessness. For now, another oil filter and a gallon oil plus shipping from Messicks cost me $45.
