Bird,
The
ballast in those fixtures call for 2 F40T-12 Rapid Start lamps. It looks like you have the right lamps in the attachment but you may want to double check the lamp type. It looks like the lamps in the attachment have the green ends on them. These might be the eco lamps in which case this could be part of your problem.
I don't think temperature is the issue because the min start temp is at about 50 degrees.
I don't think that there are any loose connections as far as the power goes because they are all lighting intermittently but you can certainly entertain that option if you so desire.
Try new lamps of a different type first. Install basic F40T12 G.E. lamps and put the print ends of the lamps on the same end of the fixtures.
If this doesn't work then the next step is to check the lampholders. Are the prongs getting a good grip on the lamp pins? Are the lampholder prongs bent? Are the lampholders cracked or broken? Are the backs of the lampholders seperating from the lampholder itself? Do the lampholders have signs of carbon on the prongs or on the lampholder? And finally, are the wires in the lampholders secure. Replace any lampholders that have a problem.
The next step is to check the ballast. Are they hot? Are they buzzing? Do the lamps burn dim even when new? Is the ballast leaking any tar? Replace any bad ballasts.
I would think that the lamps and the ballasts don't get along and that new lamps would do the trick but since you changed all the lamps at once it would be remiss to discount the other options lined out, especially the lampholders.
Good luck with those gremlins. I hope this helps.
