George2615
Super Member
Bird,
I had the same problem a while ago at work. I had Placed an order for new tubes (5 boxes of 30 -4' ers and 5 boxes of 2' U-tubes 12 per box) and got Phillips brand tubes. They had green colored end caps on them. As I started replacing them, I'd put new tubes in and the light wouldn't come on. Then I figured it was the ballast. So I replaced the ballast and put the new tubes in and all was fine. Then I noticed that every time I needed to change a tube I'd have to replace the ballast. When using my original ballast I noticed that out of 30 - 4' tubes in the first case, 12 didn't light up when installed and 8 of 12 U-tubes had the same problem. I didn't want to replace ballasts every time I needed tubes so I called the supply house, told him what ballast I had and the problems with the tubes. He replaced my entire order with Sylvania brand tubes of the same F40/CW number and have not had a problem since. I had nothing but problems with the green ended tubes and have not used them since. Maybe its just the brand of tube you are using.
