txturbo
I bought my first tractor about two weeks ago.....55 TO35. Haven't been on or worked on one since I was a teenager. My dad had a 9N that I use to use all the time. Anyway.....is it just me or is the whole country seriously lacking skill or pride in workmanship? I have such bad luck when I pay someone else to do work for me that usually I just do it myself, even if it requires buying the tools or equipment to get it done. I started working on this "it ran good when we parked it 4 years ago" tractor the same weekend I bought it. Figured it shouldn't take much to get it running again. I'm kinda in a rush because I'm closing on 10 acres on March 13th and I need to spread some dirt for the building foundation. Anyway, I had to clean the carb several times to get all the tar out of it so it would function again. Starter has been working great the whole time. Quite a bit of cranking get the carb to work and straightening out all the crossed spark plug wires. Finally get it to sound like it's going to start and I hear this terrible grinding, crunching noise and everything locks up solid. Pulled the starter out and find broken teeth on the starter drive. Nobody within 100 miles has a starter or parts. The local rebuilder has already proven his lack of ability, so I find another one that's near downtown Houston....I hate going down there. Drop it off during lunch and rush back over there after work on Friday and pick it up. All excited to hear this thing start up Saturday morning. Put it back on and do a test bump and everything seems good for startup. Turn the fuel on, pull the choke and push the button. Starter is spinning it over and I'm waiting for signs of life. It starts to sputter, push the choke in and it kicks off and struggles to maintain a clumsy very low idle. Sigh of relief......but wait....what the heck is that noise....after a split second I recognize it. The starter is still engaged. Shut it off and pull the starter again. The Bendix isn't retracting. I even tried to pry it back and it won't budge....so now I get to do it all over again. Maybe I should start rebuilding my own starters to.
