Is this a Ford 4000 TLB?
   / Is this a Ford 4000 TLB? #1
DavesTractor
Elite Member
Red Bluff, CA
Changes often!
I just took in trade a nice older TLB. I don't know much about these older Fords, so I could use some help. I looked at "The Vintage Ford Tractor Resource" on the web to try to decipher the model/VIN number, but I still wasn't able to figure it out. The numbers stamped on the pad behind and above the starter are 41301 and then 28569. The later number has a diamond before and after it which I think means it has cast iron cylinder sleeves. The loader is a 720 and the hoe is a 723. It has power steering and is gas. It has a PTO but no three-point. The hoe/loader is sub frame. It was blue early in it's life.
Any help would be appreciated.
Another picture
And another
different angle this time....
dash area....
   / Is this a Ford 4000 TLB? #6
Dave
I'm not sure what your's is , but I've attached a few pictures of Ford 4000's that I found on the web. Picture is of 63 Ford 4000
Andy
   / Is this a Ford 4000 TLB? #7
64 this time
   / Is this a Ford 4000 TLB? #8
Diesel version
   / Is this a Ford 4000 TLB? #9
is it posible that it might be a case?
just a quess /forums/images/graemlins/cool.gif
   / Is this a Ford 4000 TLB? #10
Might be a conversion. Hoe looks like a Wain Roy. Probably has a hydraulic pump on the crank snout...
