flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,538
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Ah, around here all the little 6 ft MF discs are super cheap and the 10-14 ft discs are 1000$ +++. The h1300 is way too much for your TC25d if you are using it right.
I've got a 12 ft IH disc that I need 4wd engaged for on my 100 hp MF. I did disc a bit of unplowed ground with my 50 hp Kubota but the blades were only 2" into the ground.
You're right about that. With my 54 hp Mahindra 5525 and that MM disc I mentioned earlier in this thread, the only time I can use it is in Sep when the ground is bone dry after 3 months of near triple digit temps. No way I can pull that disc after harvest in May when the ground is still soft from the rainy season (Nov thru May around here). I use my 7-ft offset disc then.
