OP
topfli8979
Thanks for the info guys. Worked 4 hours today on this machine. Replaced both relays, cleaned contacts on ignition switch,pto switch. Im getting no where. At the fuse panel on the "battery" 30 fuse I have 12v,the "Pto" 20 fuse no voltage, the "ignition" 20 fuse only millivolts, "light" 15 fuse no voltage. Took fuse panel off and cleaned, checked all wires made sure they were making contact, all good there. The only place I have voltage on the whole mower is to the starter and that 30 battery fuse. I figured the pto should "click" if engaged, I get nothing. I pulled flywheel, was dirty around the stator, cleaned up and reinstalled. No luck.
