flusher
Super Member
- Joined
- Jun 4, 2005
- Messages
- 7,538
- Location
- Sacramento
- Tractor
- Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
Again, excuse my ignorance.
If I was buying one of these tractors, what's the things I should focus on to determine quality of the tractor??
I'm wanting to purchase an older 2wd tractor in this size range and the Masseys are near the top of my list.
Diesel or gas engine? You can work on the fuel system of the gas engine tractor easier and cheaper than the diesel version.
There's a weep hole on the bottom of the clutch housing. It comes with a loose fitting cotter pin. However, this pin could be missing. Use a small diameter twist drill to clean the dirt out of the hole. A drop or two of fluid is normal. Any more fluid coming out of the hole could mean leaking engine or transmission seals.
The tractor should start right up without excessive starter cranking.
Watch the exhaust pipe on startup. There should be a puff of smoke. If the smoke continues after a few minutes of running, there could be a problem--white smoke may be a coolant leak into the engine cylinders, black smoke may be a fuel system problem, blue smoke generally means the engine is burning oil.
Remove the oil filler cap while the engine is running. If you detect exhaust flow then there's blowby caused by worn piston rings.
Make sure the tractor runs properly in all gears forward and reverse.
Make sure the pto and the 3 point hitch function properly.
I'd avoid a MF135 with Multipower. The MP on my 135 is stuck in the LOW range. I may fix it one of these days but it's not a high priority on my to-do list. The tractor works OK as is.
Good luck.
