30 FPS will give a nice, smooth motion picture. 15 FPS will still be acceptable. In the end, all it takes is one frame of someone's face to make a case. However, catching that one frame is the problem. Alot of things have to work right...
Is the camera always on or does it take a few milliseconds to warm up?
Is the unit always recording or does it start when it senses motion? How many milliseconds does it take to trigger and start the actual recording?
Can your system handle multiple cameras doing 30 FPS? How many cameras before you have to bump down the FPS?
All cameras require a power source. Most have external power supplies that require AC. Some USB cameras are powered by the USB cable, but the USB port has to be a powered one. If you load up a USB bus with cameras, they may not function, so you would need to get an externally powered USB hub.
If the PC is running the camera capture software then you most likely can use the PC to view it.
If you have a stand alone DVR, they usually come with a web interface that you can access over you network from any computer. Something like
http://myDVRname:0000 where 0000 is a port number. Then a screen pops up asking for a username and password. Then you can monitor the cameras individually, as a group or review past recordings and save them off to your PC in AVI or MPEG format, depending on the capabilities of the DVR or software.
If it doesn't come with a web interface, it should have audio/video jacks to hook to a VCR to copy to tape.
