Kapnfriday
Bronze Member
How did you attach the cup holder? My B7610 with bent bucket and bent hydraulic lines needs one.
Any more pics and details about the hydraulics for the top and tilt? Looks like you are mounting a spool valve beside the seat? I've been planning to mount one there on my B3200 for rear hydraulics, but never have gotten around to it.
Can you take a picture from the top down showing the area between the seat and fender? Then post it I might be able to tell from that..Thanks for the links, I had not seen those threads yet. I see you gained some room by swapping seats, I know it is tight there in factory tirm. Not sure if a valve would fit there on mine or not.
It's about 2.5" clearance, the seat/fender area should be nearly identical to your B7800. The valve has enough area to be mounted, just not sure if there would be enough room for the lever travel.
