RedNeckGeek
Super Member
- Joined
- Jan 1, 2011
- Messages
- 8,404
- Location
- Butte County & Orcutt, California
- Tractor
- Kubota M62, Kubota L3240D HST (SOLD!), Kubota RTV900
I have a Kubota LA724 front end loader and after nearly 2000 hours (only 600 of those are mine) it has developed about 0.060" of wear on the ID of the top rear loader arm pivots. I haven't disassembled the parts yet and don't know what's going on with the inner bore, but the two outer bores are both worn, and neither seems to be bushed. I'm wondering what the best approach would be for this repair, as the outer edges of the bucket flop a couple of inches vertically when I curl it, and that makes grading very difficult, not to mention trying to use the fork lift attachment.
My first thought is to use an adjustable hand reamer to increase the 1" bore to 1.125" and use oversize pins, but don't yet know what I'll find on the inner bore (bushing or not). The outer bushings are on a part that I could move to the mill for boring, so that's another option, but the two loader arms that host the inner bores are joined by a cross tube, making the assembly too heavy to move and position. If I get lucky and find a removable bushing on the inner part, I could either purchase or make a replacement to accommodate the larger pin.
Has anyone used a hand reamer to take out this much material? It seems like a lot of metal for something that would be done by hand. I also wonder how well the alignment would be held between the two outer bushing bores.
Any other ideas on how to proceed would be much appreciated!
