Hdoilcan
- Joined
- May 31, 2013
- Messages
- 293
- Location
- USA
- Tractor
- 2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
If you get a TNT you could float the sidelink or toplink. Your better off to have it and not need it than not have it and need it. The float valve works the same as the regular valve but you just push it all the way foward to lock it in the float detent.
Should all the remotes have float or just one?
