Your words do not offend me in the least. Believe me, I suffer from the same problem that you do in that my writing style (and sometimes my speech style) sometimes bother folks in that they assume I have much more passion in the subject than I really do.
I try to be very accurate when I make posts on this site, and try to make it known when I discuss a topic that I believe to be true but am somewhat less than 100% sure (such as my use of "I believe that..." in this thread).
I like to acknowledge when I make an incorrect statement. I had looked at a B3030 before engaging in this post, but when I had a choice to look at the cab model or the non-cab model I chose to look at the cab model with locked doors. Nearly all of my attention was focused from the seat up (PTO levers, position control lever, dash layout, air conditioner outlets, etc). I never noticed the lack of a clutch pedal as it never occured to me that Kubota would remove the clutch pedal from that large of a tractor.
After making a special trip to the dealer after this post I noticed that the B2630 and B3030 were missing clutch pedals (dont' believe they were stolen, therefore it must have come from the factory that way!).
So my corrected statements are...
(1) It is my opinion that tractors without a clutch pedal are safer when designed with a safety mechanism that allows the starter to engage only when the hydrostat gear selector is in the neutral position. This is the way my BX23 operates, and although I think this design is sometimes a pain in the butt, the "safety" side of my brain kicks in and tells me that I can live with it.
(2) I believe that the clutch safety switch is adequate for tractors with a clutch pedal, such as my B2910.
(3) Hyrostatic transmission tractors should have a safety switch that does not allow the tractor to start when the hydrostatic control pedal is out of the neutral position, regardless of whether they have a clutch pedal or not. Kubota has this safety featue on all Kubotas that I know of
(4) I incorrectly assumed that the B3030 had the same drive train as the B2910 but had a new sheet metal design.
Kelvin
