I'll do the same with pictures StrangeRanger.
Pretty sure that a 4" stroke will be fine for my uses - I've never so much as adjusted my sidelink. In fact I spent a while wondering whether I should just get a top link but finally decided to spring for the whole deal.
I was looking at the space behind the seat, by the ROPS, where I wanted to mount the valve and was wondering if there will be enough room between the ROPS and the rear right flasher... donno. I'll wait till I get the valve and get it assembled before making a final call on mounting. The other alternative I was thinking of is bolting piece of steel right on the fender - jutting out towards the seat and mouting the valve right on that.
I don't have a friend with a welder so I'm going to either find one or find a welding place to do it for me. I found myself ogling the Lincoln mig welders at the local TSC today. Never welded anything before but sure would be nice to be able to do an L shaped bracket at my convenience..... I'll add it to the (very long) wish list. It is far beyond the air compressor which is next thing I will add.
On fittings and hoses I'll bet that you can get most of them ordered online, but, as WayneCountyHose has advised before, its a good idea to let a local hydraulic shop help you out.
Here is an awesome thread on making sense of hydraulic fittings. WCH in his first post pretty much sets us upon the right path.
- Bascially get -6 (3/8) hoses with -6 (3/8) female JIC ends.
- Then we need two SAE o-ring -8 to -6 JIC male by male adapters for IN and PB ports on the valve and then one SAE o-ring -10 to -6 JIC male by male adapters for the PB ports.
You will have to think about the angle of the o-ring by JIC fittings once you get the valve mounted and / or get an idea of where you will be routing hoses from.
While I don't think he said explicitly, I think we will be wanting swivel -6 JIC ends on our hoses.
The above only covers fittings for plumbing the hydraulics to the valve.
The work ports should be straightforward I think. I think we will need eight 90 degree SAE o-ring -8 by JIC -6 male by male adapters - as the work ports are on top of the valve. The quick couplers will go onto the JIC -6 end.
I'm not quite sure whether we should be looking at four 90 degree adapters and four 45 degree adapters instead of eight 90 degree adapters.... again, I think the valve is going to have to be in place and hose routing thought about for these details.
We'll have to wing the other end of the hoses that fit into the loader PB port, hydraulic block PB port and tank output.
