Builder
Super Member
- Joined
- Feb 22, 2006
- Messages
- 6,138
- Tractor
- Kubota, AGCO, New Holland LB
Gooseneck is the only way to go.
That and a 4R100 transmission.
The reason I mentioned "maybe" a gooseneck is if I were to go with a larger trailer to carry the 5,000 lbs and not be using a little trailer with some of the pallets in the truck bed, then I may want to just move up to a trailer that could also carry some of the equipment I have.I would agree with the majority here.
I own a 16' twin axle car/equipment trailer, and a 30' gooseneck. If I'm hauling something, if I can fit it on the 16' that's what I'm using. Anything more, onto the gooseneck.
Loading everything on the trailer would be much easier loading/unloading IMO. Just balance the load to put some weight on the hitch.
While goosenecks are great, I would think a bit overkill for your situation, and more $$$ to purchase.
Good luck!
I have too many trailers. They are a PITA to park, maintain, inspect unless you live on a lot of acreage. Most of my farm customers have no trouble allowing me to store equipment on their property, but I have to consolidate into 1 trailer to go along with my 20 ton. Probably going to be a G/N to pull behind a duallie.
My 18K tilt was a great trailer for the Kubota, but too small for the LB115. I need the max G/N I can get for the duallie and my 20 ton for the Backhoe and anything bigger I rent.
http://rides.webshots.com/photo/2474350880060323780dbFOdj
Yes that would work fine as well.:thumbsup:
Thanks for the update.
I see you can get "car hauler" types built up to 14K, even 16K, and the lower height is appealing. I could deal with loading and unloading the pallets between the fenders but my concern would be that the rear tractor tires which are set at 68" center-to center probably wouldn't clear the fenders. The ideal solution would probably be 2 trailers like scoutcub has, but for now I have to start somewheres
Proper load distribution would probably have the rear tires behind the fenders, but you would have to try loading and towing to be sure. It can get scarey/dangerous in a hurry if the load is too far to the rear.
OK, I looked at a 14K Bri-Mar low-profile on a local lot. It measured 83" between the fenders although the specs in the brochure say 81" deck. For the 83" you would be driving the edge of tractor tires right along the top of the side rails. Most of the printed specs I've seen for other makes range 80-83".What is the width you're seeing between fenders on the trailer(s) you like?
