I don't see how a losing a bit of fluid would affect anything. What about the residual fluid in the rock picker itself? There must have been some.... Could mixing that with the fluid already in the tractor have improved anything? Maybe it had some lubricating property that the original fluid needed?
I am just about to go do the 50 hr service, so it will be interesting to see if replacing the filter and fluid will have any effect. It would be a bummer (and a little ironic) if it comes back again.
maybe it is in the 3 pt and the 7040 isn't lifting that heavy rock picker up high enough to trigger the 3pt relief valve....assuming that is where the noise came from of course.
It is a pull-type implement, so no TPH involved. I haven't noticed any correlation thus far with the TPH.
What does matter is that higher RPM means a higher hydraulic flow rate and that means the hydraulic fluid gets hotter....it can get lots hotter.....and heat can be a problem. So keep an eye on the hydraulic temperatures. If that's OK you're good.
glad it's working,
rScotty.
Funny you should say that - I thought when I was swapping hoses that they felt hotter than usual, but I thought that perhaps it was just my imagination. How could I know if hydraulic temps are too hot?
