Mahindra 1815 blowing 50 amp fuse.
   / Mahindra 1815 blowing 50 amp fuse. #11
I removed the jumper bar and (I'm not sure what scale I was on) but I got 6 on all 3 glow plugs and I took the glow plug controller apart because I couldn't find a ground in the connections on it and every thing looked new, coil, contacts, and circuit board showed no burned areas so I would think a 50A short would be obvious in the wiring somewhere but I cant get a wiring diagram because the web site prints out a 3 page diagram on one page in micro print, imposable to read.
divide and conquer, disconnect all the glow plugs and try, if it blows its the control cct, if not connect glow plugs one at a time and try. if it points to one particular plug isolate it and try to see if the fuse stays intact,
   / Mahindra 1815 blowing 50 amp fuse. #12
75 ohms would indicate a dead short that would cause the fuse to blow.
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Terex LT40 Boom (A56438)
2016 RAM 5500...
New/Unused Quick Attach Rock Hammer (A57454)
New/Unused Quick...
CAT930K (A58214)
CAT930K (A58214)
(11) Assorted Steel Rims (A57454)
(11) Assorted...
2018 Covered Wagon 16ft Enclosed T/A Trailer (A56859)
2018 Covered Wagon...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
