Hey Guys, I'm looking to get a front mount blower for a kubota tractor. I know they both are expensive, buuuuut my question is,is one better than the other. I know that you need either a mid pto or rear pto apparatus to run a mechanical and also some type of hydraulics for the other. Any thoughts? Thanks,
My question to you is this do you own this frame size tractor or are
you shopping for it or tractor in general?
Do you realise that a Grand L will allow you to have 2 or 3 three rear remotes to control a
rear mounted snow blower with ease?
Will you purchase a loader, wheel wieghts, good rear snow tire chains either the ring type
or logging chains ?
Will you have the tires loaded with rim guard or windsheil washer fluid in addition to the wheel
wieghts and chains swhich are a must have item in heavy snows?
Getting a Grand L and a Pronovost Group 1 P-720-74s now blower with hydraulic chute rotation
and spout control will be much more productive in snow removal with a pronovost front mount
kit and the reversing gear box if you want o have a front mounted snow blower that can be used
on the rear as well.
You are limited with a front mount snow blower to the size of the auger housings ability to pull snow
into the impeller and in heavy deep snow falls you will have much snow that wil be falling over the
snow blowers housing and under the tractor as it advances where this would not occur with a rear
mounted snow blower as the auger open housing pull all the snow into the impeller.
And the under frame mount will reduce your ground clearance!
Have you taken the time to sit down create a decision tree to come to a conclusion good or bad?
Do you really need a tractor of this size and wieght when a BX2660 with a wider rear blower can do the same job
at less cost?
You will find that having a rear mount blower is better simply because the view is better and you
are up and over the snow blower giving you a full field of view where you cannot see in
front of the snow blower in a front mount set up.
All you may need is need is a firm pillow or the upgraded kubota seating option
to reduce lower back stress while you are slightly turned in the seat and
the open station allows you to use your left foot to control the directional
pedal and releasing the pressure on the pedal will allow the tractor to come
to a stop with the rear blower being on the ground.
A front mounted blower may or will limit your ability to trade up to a different
machine as it may not be useable on the newer unit you wish to trade up to
where a rear mount will go from tractor to tractor with no issues
other than a possible pin mounting change over from type 1 to 2 pin size?
Snow removal speed is measured in tons per minute not width of cut when
discussing a snow blower so please keep this issue in mind first when
examining the issue.
A handy thing to keep in mind;
88 feet per is one mile per hour
176 feet per minute is 2 miles per hour
264 feet per minute is 3 miles per hour
352 feet per minute is four miles per hour
The snow blowers cutting hieght impeller diameter and impeller drum depth are of primary
importance when making this decision as the cutting hieght will be what determines the cross
augers ability to feed snow and allow the impeller to cast it aside.
The open auger design / open ribbon type allows for faster conveying of snow to the impelller drum but
The impeller drum can be flooded and impede its ability to cast snow.
At 3 miles per hour you can cover a 500 foot drive in less than
2 minutes in reverse in one pass for any size blower in low snow
fall accumulations.
And be done in less than 5 minutes with two passes.
The snow fall tonnage not the depth is what is the primary issue
for any snow blower purchase.
You can purchase a very narrow width snow blower and have the
ability to remove hundreds of tons per hour with a 4 foot width of cut
using the pronovost side walk snow blower as an example using a
50 horse power machine.
In some tractor owners cases they buy a much wider rear mounted snowblower
and simply travel a bit slower in reverse to accompolish the SAME THING with a
smaller tractor so keep that in mind also.
Dont expect to be able to remove snow at the speed of mowing in forward unless
you can afford to purchase a machine that has 80-90 horsepower if you insist
on a front mounted snow blower which will cost much much more than the same
size rear mounted blower.
