I haven't jumped into this just yet, as it's summer now in CA, I don't really run the tractor that much because the ground is dry, dusty, and hard.
I've been fixing little thing on the tractor in the mean time, like the fuel gauge, generator, voltage regulator, exhaust manifold, trans issues, cleaning the radiator/oil cooler fins, belt, etc.
As I'm almost done with those smaller jobs, I've been saving the biggest job for last...which is the engine. It still starts up on the first rotation, seems to have plenty of power, and begins blowing oil into the exhaust manifold (which has some cracks in it) after about 5 minutes. I'm guessing the oil is coming from the valve guides.
My neighbor said if you increase the rpm on the engine, then let of, then push on the gas pedal quckly and you see a big puff of smoke out the back, than that is a good indication of oil getting past the valve guides.
I've been reading a bit in my MF 203/205 industrial workshop manual on what is involved with a major overhaul and I'm feeling a bit daunted by it, wondering if I'll be able to do it. I'm a bit nervous about things like getting the old cylinder liners out and the new ones in as I don't know if I have all the tools for that. I have just basic tools.
Knowledge-wise I have rebuilt a volkswagon motor before and a couple 2 stroke dirt bikes. I grew up around mechanics as my Dad owned a Chevron station with 3 service bays, but I don't remember seeing any engine rebuilds, and I had a mentor mechanic help me with the volks engine back then where we used his tools for the rebuild.
I don't mind investing some money into some tools, but can't at this time go hog wild.
I'm wondering if I shouldn't first try dropping the oil pan and replacing the oil pump and also getting a valve train set and pull the head off and get the guides/vavles replaced, and have a machine shop help me with the valve seat resurfacing.
One more thing, there is some engine oil coming from the rear of the engine, I'm guessing from the rear seal, which I think I was told is a rope seal. I'm guessing I should replace that too, which means pulling the engine off the trans...but do I have to split the block to replace this seal?
If anyone could offer any kind of advice on my thinking above, I would greatly appreciate it. Is it worth trying the head, oil pump and seal first...than run the tractor for a while and see if the pump can keep the pressure up to an adequate level?
I understand if these jobs don't work, I'll have to get a buy a new head and oil pan gasket in the future, in order to go thru this again and rebuild the block.
I'm just wondering if the perkins couldn't do good for a number of years without having to get into the block...or should I just do it, and take the time to figure it out. Thanks for any advice
