I suspect you are right about that, don't wan't to over work the operator. You also have to get the hinge post plumb and enough concrete to keep it that way, adjust the limits correctly and use an electric latch to reduce wind damage.
I have chosen the heavy duty models and increased radius for the pivot which will decrease the load while slowing down the gate swing speed. That has helped alot but not made them bullet proof.
How much better is the Apollo equipment? I may wan't to try one on my new shop gate to see how dependable these would be. Being able to sell a GOOD operator would be beneficial to me.
on my MM I also installed a seperate post for the operator to hinge on, and lef the gate post by itself, then i bound those 2 posts together with 3 pieces of 5/8 allthread studd and double nuts. both posts concreted.
I like tube gates since I have horses. way less wind drag than a panel gate. I also see alot of decorative iron gates on these controllers.. and wheile they meet the 'length' criteria.. I know they are over the weight limit.. thus more inertia problems for the worm.
The apollo equipment is supurb.
More or less easy to install, You can buy component parts, like the board in the controller box, the box/enclosure itself ( has nice seal, place for battery, push button overide and key bypass / lockout. the motor's are very HD.. we swing 20' steel gates on them in push or pull. the one at our rock mine is a 20' chainlink gate, and it is in a pull configuration, and due to grade, pulls UP hill at about a 25' angle..
rf rcvr is a seperate replaceable unit.. can use a variety of rf keypads or wired keypads, as well as hand held xmitters ( NOT MM compatible ).
overall.. they are the best gate openers I've dealt with.
I sometimes have to put them up on jobs in a solar confituration, and over the years have installed them at the owners hous(es), and at our mine and work locations.
the only issues I ever have to go out on service calls are for:
dead battery in a keypad
car hit the fence / gate, repair / repalce parts as needed.
tree dropped right onto the pc board enclosure making it a neat looking pice of scrap metal with a crushed battery, charger, and bits of circuit board and wire hanging out. incedentally, this knocked the gate post over at a 45' angle, and swung the gate stickin into the air on a complex angle with the worm as part of the short right triangle down near the base..
worm worked fine after that.. had to splice the multi wire harness from it as the tree cut the whip 3' from the motor, and a new whip was a bit much, especially since I was buying a new board, enclosure, xcvr battery and charger and was on a budget.. whip would have been another 75$, replaceable at motor housing.
I highly reccomend them...
soundguy
