attaboy
- Joined
- May 16, 2009
- Messages
- 25
- Location
- NorCal
- Tractor
- "50 Austin-Western Super 88-H, '52 Ford 8n, '80 Kubota L285, '85 Komatsu D21-P5, '88 Wacker WHK 90, '90 Komatsu WA30-2, '95 Komatsu PC50-2, '07 Jinma 354
that make sme steaming mad when someone pushes my gate open to walk thru, KNOWING it has a gate opener on it...
soundguy
I concur. Not just people trying to get through though .. I had an arm bent back from a wind gust .. outside tube must be alum 1100 or something .. should be 7075 ... geesh. Bent like a cheap coat hangar.
My main complaint with MM .. is the remotes. We have multiple (MM) gates on two ajoining parcels .. figured I'd reduce the number of remotes by one, by getting some two button remotes .. same price as singles at TS .. hmmmm.
As it turns out ... the two button MM remotes .. only use a 4x3 digit code (times two), instead of the 9x3 digit codes used in the single button remotes. Sooo .... the two button remotes are totally useless, unless you wanna open up the controlers .. and have them re-"learn" what the two button remotes are set to. We have four MM openers installed here (22 acres) and two more planned. Even my Jag can accommodate 3 .. but it's a real pita to juggle all this "remotes" stuff.
I was really suprised and dismayed, when I opened up the 2-button MM remote, to find they just split the hardware inside. While indeed ... this is mountain rural here .. code security is not the issue .. but don't need one remote opening 3 gates .. lol.
Anybody make a MM compatible multi-gate remote besides the one built into a Jaguar (still only 3) .. please post ... and Much Appreciated ... TIA
