treemuncher
Bronze Member
My vote is the biggest you can move. If that's not a valid concern big iron is cheaper.
This is the only intelligent response I've read on this post. Unless you plan to start a contracting service with a mini-ex, buy a big hoe and get the job done quickly and efficiently. Dollar for dollar on fuel costs, you will save money with a larger machine. Clearing work is best performed by large machines that can handle the stresses better and handle larger loads with every pass. Mini machines were designed for utility work and light landscaping, not for handling trees and stumps in excess of 6".
While my PC200 is suitable for most jobs, if I was to be doing slash and burn clearing for a living, I would consider nothing less than a 270 or 300 class machine. When I got out of dirt work, I sold off my JD550G and used that same money to purchase a Liebherr PR751 (approx D8.5 size) knowing that I would not be moving it much and so that I could get so much more done on my property when projects came about. Sure, the 751 burns 20 gallons per hour but it pushes over 14 yards in a pass and gets a lot of dirt moved fast. How many weeks would it take a mini-ex to move in what that machine moves in a hard working hour?
Regarding mobilization: It's easier for me to write a check to have it moved than deal with the hassles of my own lowboy anymore. I contract out all of my large moves any more. Fewer hassles and more efficient for my business at the end of the day.
Big iron, once on the used market, usually sells for way less that the smaller stuff. There are some very good bargains to be had for farm use. You won't wear out a big machine as fast as you will a small machine if you are doing clearing work, unless you stick to bushes and tiny trees.
