jinman said:
Dave, a higher hp engine will produce no more flow and no more power to the wheels than a lower hp engine if their rpm is the same. If the engine bogs down on a lower hp engine, of course it will produce less flow.
....and why does an engine bog down? Not enough power to produce
the flow demand. If power were not important, why doesn't your
tractor have a 2hp engine? Power is about doing work. If you try
to drive your TC35 up a 10% road in HI range, it will bog down. If you
want to roto-till with a 5-footer more than 1 MPH, you will bog
down. Our 5000 lb tractors have only 35hp engines because high
power is for doing things fast. It has nothing to do with force or
traction. (My tiny 2200lb car has a 140hp engine because it takes that
kind of power to go 130MPH or accellerate quickly.)
jinman said:
But if the lower powered engine does not bog down, you cannot gain anything by increasing hp. That is the case with our tractors. If the TC35DA cannot maintain rpm and the engine bogs down, then there is something to be gained by increasing hp.
That's what I said if you look at my previous post.
jinman said:
If the engine has plenty of power to put the HST transmission into
bypass without bogging down, then a 50 hp engine will get you nothing.
I own a TC45D and I cannot use nearly all the torque and hp of that engine through the transmission. And if I'm in a situation where all wheels are spinning and I'm not making progress, all the power in the world won't make it any better without more traction.
Of course. Force applied to the ground is about traction, a function of
weight and friction. Gearing (thru torque multiplication) can apply enough
force for motion with the smallest of power plants. The question is how
fast do you want to go? The designers made a hp trade-off for the
amount of work they expected a particular tractor to perform.
As for examples of "enough" power, I am usually satisfied with only 30hp
from my Kioti CK30, but I do not do ground-engaging work, and fast travel
uphill is rare. I bought a CK20 last year and with inplements, it can not
propel its own weight in M range up ANY kind of slope. Needs more power
for that activity if one wants to go more than 2MPH.
jinman said:
If I was wanting to turbo-charge a TC35, I'd go get a gear tractor and figure how to get more traction at the wheels. Maybe dual rears or increasing weight. A TC35DA with HST transmission is a bad, bad choice of tractors for an engine hp increase of any significant amount.
If I wanted to do a turbo, I think I'd take the TC35DA down to a NH dealer and trade it in on a TC48. Then I'd turbo the TC48 to get the power of the TC55. The gear driven transmission will produce much more satisfactory results.
I don't know why you say that. There are 100hp tractors that use
HSTs and turbos....look at some of those nice Case construction
machines. Any decent manufacturer will make a gear box robust
enough to handle the engine that comes with it, plus a big safety
margin. It would not surprise me at all if the TC35DA shared the same
gearbox with the TC40 and 45, based on the published weights.
The main diff seems to be the 3 cyl vs 4cyl engine.
There is no question that HSTs are less efficient than conventional
gear trannies, esp at higher traveling speeds. (Ever notice that hi-hp
construction machines with HST are not desigend to travel very fast?)
HSTs are a trade-off for better control, not speed.
As for trading in a TC35, I am hoping someone does that around here,
as I have a standing offer with the local NH/Kub dealer to buy a broken
customer trade-in, ideally a HST TC35. BEFORE he trades it in. I have
not taken a blue tractor apart yet and it is high on my list.
