yea i know what balance rates are
my truck is a 2005 LiLLY
not an overheater, no problems with electronics, not a single problem. must have gotten lucky
yea i've seen (read) a few guys have problems with the injector control harness. even a guy had a fluke with the FICM, but i don't think it's wide-spread.
what i did to prevent the 'rub through' on some of the wiring harnesses is cut the ziptie, wrap it in heater hose or pipe insulation (foam) and ziptie in back into place. problems happen to those who don't prepare for them.
been a really good truck to me though, and we'll see what this crud i'm pouring in there does one day.
superdiesel (not here, the one from dieselplace.com) has been running large (way higher doses than me) in his fuel (including used and filtered motor oil/hydro/2stroke/atf/ect) for many thousands of miles. he lives in alaska to boot. i also contacted him recently about this subject (oils in tractor fuel) and he told me that he runs the same setup (30-40% IIRC oils) in his JD4020.
if it was a HUGE no-no, problems would have already arised.....maybe. he has an LB7, and has not replaced one injector.
so, how you like changing LLY injectors after a day of changing LB7 injectors?
