Aaron Carr
I use a Bridgeport everyday and they are very good pieces of machinery. But I have to say that New Holland probably will give better service.
I have a portable shop crane that I plan to use to disassemble and reassemble the Bridgeport, so that's not a problem. The biggest issue I'm thinking about it the transition point as I begin to tilt the base (1,000 lbs) from a level position at the top of the stairs to the 45 degree angle to slide down the stairs. I'll move the base into position at the top of the stairs with my portable crane, but somehow I'll also need to hook up my cable winch that I plan to use to control the slide down the stairs.I've talked to some boiler installers that move 2500 lb boilers into basements in two pieces by nailing 2x10 skids on the stairs and sliding the halves down with a comealong holding them back. The problem at the bottom is getting the two halves stacked again.
One had a little aluminum manual forklift that did the job nicely.
Well, if I had the room on my property, that's what I would do. But I don't, so I'm stuck with moving heavy things in (and out) of the basement. At least I have stairway access to the basement from the garage. Some of my friends have to move their heavy machinery into the kitchen in order to access the basement stairs. That's a LOT HARDER to explain to the wife!Oooh aaaah. Very nice
I think you need to build a shop instead of having the trouble of putting it into the basement. At least that's what you should tell the wife!!!
