JC-jetro
Elite Member
Howdy all
A buddy of mine gave me couple of old 16" dia disks and after looking at a pile of scrap metal and what I have seen here and there decided to build me one. I can change the angle of attack and depth pretty easy. I'm afraid it might not be wide enough, although should be able to easily add it on to my single row cultivator. I'm done with my summer garden but will try it this fall to see how it work. I'd appreciate comment specially from the guys who have and used hipper before.
Disks did not have a hub. Luckily the dia of the hole was pretty close to a 1" threaded coupling. Push the coupling thru, welded on both sides. used a solid shaft from an overhead door for the spindle but it had a lot of flop. Used a short nipple with the coupling and cut it flush, used the rest of short nipple and put on the other side. The spindle fitted nice and tight but easy to turn . I then drilled hole, tapped and put a grease zerk for the hub. It has plenty of room to hold the grease in.
Used a piece of 1 1/2" sch 40 steel pipe, poked two 1"dia holes in it and welded on the solid shaft/spindle.
used and old horizontal draw bar, to mount the disk/shaft. Made a channel section to hold the pipe tight. Added a welded on nut and a bolt to keep the pipe from turning.
Put couple of 1" spacer washer, bend the piece of cattle panel galvanized wire rod to keep the disk from coming off the shaft/spindle and greased it good.
Used a piece of uni-strut to make the top link connection to keep the horizontal draw bar from spinning.
All I need to do is to take it to my place and give it a go.
JC,
JC,
