Hi Everyone!
Thanks for the flurry of responses! Some of you have asked for more info so I'll try to answer your questions.
Tractor Specs:
Deere - 5525 (75 PTO HP), ROPS, MFWD, 12x12 e-PowerReverser, Straddle mount, tilt-wheel, 2 rear SCVs, telescoping link ends, 480/30 R1W tires, ~3300lb 3pt lift capacity (24in from ends)
Price: $40-$41K with Quicke Q940 loader (should have a firm number later today)
Kubota - M9000 (80 PTO HP), ROPS, MFWD 8x8 hydraulic shuttle transmission, 2 rear SCVs, telescoping link ends, 480/30 R1W tires, ~4600lb 3pt lift capacity (24in from ends)
Prices: $36,800
Quicke FEL:
I selected this one because Kubota does not offer self leveling as an option on the M9000, thus I never looked at the Kubota loader specs. I need self leveling for use with pallet forks so I can move stacks of lumber around without dumping it on myself! /forums/images/graemlins/smile.gif
I did look at the Deere 542 loader. The Quicke can hoist 3800lbs while the Deere is limited to 2800lbs. Plus the Quicke mounts it's valve on the loader frame (stays with tractor) thus keeping the hydrualic lines from running underneath the tractor which is important when you are running in the woods. In addition, Quicke offers a "quick disconnect" option that allows you to disconnect all four hydraulic lines from the FEL at one time, under pressure! Thus I'll be getting the Quicke loader on what ever tractor I buy.
Dealers:
In this comparison, the Deere dealer is much better than the Kubota dealer - I've been working with them for 5+ years.
Cabs:
Since I do a little logging to feed our sawmill, I'll be going with the ROPS version.
Ergonomics:
The major difference between the two (the Deere straddle mount vs the Kubota) is the placement of the shift levers, foot throttle, and steering wheel.
The Deere has a tilt wheel, the foot throttle is pleasently under my right foot and the shift levers are one the dash (Reverser) and on the right (Range+speeds).
The Kubota has one shift lever (Range) on the left, the reverser on the dash, 4 speed lever in the middle where you have to straddle it, and the foot throttle stuck way out to the right side of the brake pedals. I find that I have to cock my foot out at an angle to the right to reach it. On the ROPS model, Kubota does not offer a tilt wheel. This causes me to have to pull the seat up fairly close the dash to comforably reach the top of the steering wheel.
Electronics:
My major concern about electronics is long term failure - and the cost to repair. I'd hate to have to split the tractor to replace a failed solenoid. But, as some have pointed out, there's lots of cars on the roads with lots of old electronics in them.
Thanks again for all of the input! I have to make up my mind this week - it's driving me crazy!
