dave1949
Super Star Member
I was planning on doing that with the brush, I guess that would be an option if I had someone who had a done one before. I always worry about it getting out of control. But I have to check what the regs are.
You will most likely need a burn permit. Timing wise, spring can be a high fire danger time. From the time the snow melt is over and there is bare ground, until things green up good, is not a good burn time.
Since it was tilled 20 years ago, I wonder if you could use a sub-soiler to rip up the roots? That would be after cutting and getting the brush out of the way. Sub-soilers are not expensive to buy. A plow might just load up with roots til you are dragging a big pile around behind you with the share point out of the ground. The coulter blades wouldn't cut roots of any size I don't think.
I'm not sure it is realistic to try and make it plantable this spring doing it yourself, maybe next spring if you keep at it over the summer. There are probably some rocks that have risen to within tilling depth over the past 20 years.
