Westshore and Timark I'm not trying at all to throw stones at your machine choices. I myself own a S220 AND a RC50 and have been very happy with both just as i'm sure you are with yours. I also don't pretend to be an expert in the brush cutting business, you guys would be that expert. I do think of myself as being above average when it comes to equipment kowledge especially skids and mini's since I sold them for over 8 years. I have spent a fair amount of time in the service shop although I don't claim to be a mechanic. I was only repeating the hydraulic information that was relayed to me by my ASV salesman. I admit that he is probably biased but I have also found him to be a straight shooter. He has passed on to me the hydraulic numbers that he got for the T320 and I will paste them here. I was not there for the test and all I ask is that you don't shoot the messenger. I don't know where this test was conducted only that it was done not long after the T320 released the suspension.
Results of T320 flow testing
Heat test:
Engaged high flow, 40.5 GPM, 350 psi back pressure- No load. Immediately saw hydraulic temp rapidly rising with no load. Tem increased to 150F before we applied load and was climbing.
Applied 2000 psi load:
2:15 the fan kicked to high speed. Oil temp at 220F
3:33 Oil temp 240F
4:10 hot oil temp light came on. Flow meter read 250F. T320 machine shut down automatically (engine died) before we could manually shut it down.
Flow testing:
start at 160 degrees after 15 minute cool down:
40.4 GPM @ 382 PSI
38.9 @ 1000 (22.6 hp)
36.55 @ 2000 (42.6 hp)
34.99 @ 2500 (51 HP) Maximum actual peak hydraulic hp available
31.2 @ 2750 (50 hp)
28.6 @ 2800 (46.7 hp)
26.1 @ 2900 (44 hp)
21.1 @ 3000 (36.9 hp)
13 @ 3100 (23.5 hp)
12.5 @ 3200 (23.3 hp)
11.5 @ 3300 (22.1 hp)
11.3 @ 3400 (22.4 hp)
4.2 @ 3500 (8.6 hp)
0 @ 3550 max
Temp was 242F at end of test. Flow at no load with oil hot was 39.18gpm, 292 psi back pressure
I have never seen a flow meter hooked to a T320 but I have been involved in some Bobcat flow testing for trouble shooting and I have yet to see a machine actually put out the printed flow at the printed operating pressure. I'm sure that all the other OEMs fall into the same boat. I'm sure that any of the guys here that work for DenisCimaf can attest to that without naming skid steer brands due to sensitivity. I'm also sure that they know which brands have the best cooling and "actual" hydraulic hp available at the attachment. Again, I'm not asking them to name brands as I'm sure they want to and should sell their attachments to all makes since customers make the preference.
Heat test:
3:33 Oil temp 240F
Flow testing:
40.4 GPM @ 382 PSI
31.2 @ 2750 (50 hp)
26.1 @ 2900 (44 hp)
13 @ 3100 (23.5 hp)
4.2 @ 3500 (8.6 hp)
0 @ 3550 max
