OP
candersen10
- Joined
- Mar 27, 2007
- Messages
- 267
- Location
- Phoenixville, PA
- Tractor
- Cat 262c, NH TN75, JD 6430 premium, JD 5325, Kubota BX2200, Ford 1710HC, JD 333E, JD3720, Farmall 504, Farmall 404.
By overheating I mean that it runs around 7 out of the 8 bars on the heat indicator. Ocassionally it will run all the way up to 8 bars somewhat rapidly. Obviously I am very careful to turn the machine off immediately when this occurs and I will let it sit for at least five or ten minutes before turning it back on again. This overheating has been occurring most recently while running the machine with a 6 foot landpride mower in around 1.5 foot tall grass in medium range going about 5 miles an hour. The one field I have to mow is around 45 acres and the outside is 1.1 miles around the entire field. With a 6 foot mower this takes about 2 days to mow so the extended period of running the tractor at 2500 rpm/540 PTO rpm certainly contributes to it's overheating. In Comparison, the TN75, obviously a more powerful machine, runs with the H/C temp needle no higher than the very middle of the range. It is also much smoother to run on rough ground because it is heavier. Ultimately, I think the problem is just that the Kubota 4630 is too small for my purposes. As for the TN75 transmission problem, the dealer can't look at it until Tuesday so we'll see what exactly happened to it then. It has the syncro-command 8 by 8 transmission with the power-reverser. The people operating it are very careful not to abuse it so I'm sure that's not the cause of the problem.
