MHarryE
Elite Member
- Joined
- Feb 15, 2009
- Messages
- 2,946
- Location
- Northeastern Minnesota
- Tractor
- Kubota M7-171, M5-111, SVL75-2, RTV900XT & GR2120; CaseIH 1680 combine
DieselnHooters said:What do you mean by required? Like they wouldnt start without the plugs?
My 2005 MX5000 starts fine at 24F with no pre-heat. I even started it cold down to 10F once out of curiosity. 20F is my normal cut-off point on using the glow plugs.
Two would have started and run roughly without glow plugs but that does add stress to the engine and why do that if I don't have to. The third needs glow plugs when cold even on a 70 degree day.
Today I had to start the combine in my avatar to put it in its proper storage position as we stow things for winter. It has a 225 HP direct injected 7.7 liter engine. Thirty degrees, took about ten seconds cranking before starting with a lot of smoke and rough running. No glow plugs on the engine but it does have built in ether starting aid. Only thing is the can installed is empty because we don't use it in below freezing temps - except for something like this.
