justinl
- Joined
- Sep 4, 2012
- Messages
- 6
- Location
- Mineola, Texas
- Tractor
- Cat 287C, Vermeer SC 372, John Deere 6430
have you looked into having it mulched down?
Instead of a dozer, I'd recommend a track loader for clearing. Theyre usually cheaper than a dozer and you'll not push all of your topsoil away plus you can easily pop trees/stumps out and carry them away. Something like a 955L cat, 175 IH, etc. would be a good size. The teeth on the bucket works great as a root rake and in the areas your describing, you could rake most of the bushes and trees into piles and burn or dig holes and bury.
I'm currently running a 955H cat clearing mature hardwood forest for pasture and it works great. I have a dozer, havent started it in months (guess I need to at least start it). I do have a 55 hp john deere 4wd with FEL, but I dont like beating on it when I have the old caterpillar to knock trees down with and clear the ground.
Good luck...........
LazySusanFarms said:I bought a turbo saw for the 3 point. It has worked well and will handle a large tree. A grapple will be mandatory no matter what you do.
I dont want to steer you away from new equipment, but if it were mine, I'd make use of the equipment you already have.
IF you have a heavy-duty bushhog, it should easily handle 3" and smaller trees/sapplings. Go around the ones that are too big. Go back and chainsaw the off flush with the ground . The just keep up with the bushhogging and you'll be all set.
