Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,998
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
Funny that this topic should come up after just yesterday I had to remove and replace about 3 gallons of old gas from a golf cart. It had been in there for about a year. Last month it fired up and ran good but yesterday if wouldnt fire at all. I pumped all all the gas and replace it and all was well, not gummed carb but the old gas was really dark colored and had a bad smell. I poured out a bit of it and thru a lighted paper towel on it and it didnt flash off like gas, it was more like diesel and smoked to high heaven with dark black smoke. I guess that it lost most of the volatiles out of it. I had the same thing happen with my lawnmower that had gas left over from previous season. It wouldnt start the mower but it wasnt off colored or smelly so I put it in my truck and it ran ok. THIS stuff will be used for brush fire starter using extra caution to stay upwind and back away from it to start. If I have to use gasoline for fire starter, I use a large stick with some fuel on it to start and then throw it from a long distance and always stay upwind since the fumes will drift downwind.
My normal firestarter is used motor oil or used hydraulic oil. It works the best for this and burns hot and long with no danger of flash burn. I will likely just mix this gas with my used motor oil to get something approximating diesel since i just drained 2.5 gallons of motor oil yesterday from my tractor.
