Wayne County Hose
Veteran Member
- Joined
- Aug 24, 2007
- Messages
- 2,352
- Location
- Wayne County Pa.
- Tractor
- Massey Ferguson model 85, Allis-Chalmers WD-45
SPYDERLK said:Prevalent in this post, and many in the thread, are extreme statements. Problem is, to a little cooler analysis they never always hold up. Take the one above. It will get you in real trouble to err very much on the loose side because if the fastener is employed in a demanding situation its tightness becomes paramount. If its loose the joint will squirm around, wearing the joint and the threads, and backing out the bolt. A hi strength bolt in such a situation can severely damage the parts it is holding, especially when several fasteners are meant to be holding evenly- loosening of one allows prying against those adjacent. Strong bolts can break castings in this way. Assuming the joint is correctly designed this would not happen if the speced torque, or in many cases a few % above spec were used. I say "in many cases" because seldom are bolts employed to their max, where they are torqued to yield [plastic deformation], and are not to be re used. Connecting rod endcap bolts are sometimes speced to be used to this level, and the wise person replaces them, but the less wise usually gets away with reuse. --- Our tractor uses usually spec torque well short of yield for the appropriate fastener, leaving a significant margin of unused capability. In particular, with things like wheel lugs and loader mount bolts, thats why the experienced mechanic can work with a familiar impact wrench. Hes playing in that "about right" area which can actually extend more above spec than below it. You wont find him doing it with your head bolts or rod caps tho.larry
There are so many erroneous statements above I just don't know where to start. What is extreme is when people say that they can torque a bolt with an air gun and get it "about right." My compressor kicks on at 110 lbs and off at 130 lbs. That's almost a 20% difference in torque output. And to think that you can feather the trigger to get the torque you want is just ignorant. I have tried this with other mechanics. Try torquing a bolt to what you think is 100 ft lbs., then take a good quality torque wrench (not a Craftsman either) and see how much torque it takes to turn the bolt. I'll bet the farm that 9 times out of 10 that you are not within your torque range.
Connecting rod bolts are not spec'd to torque. They are spec'd to stretch. The engineers use a bolt stretch gauge and tighten them until they get the proper amount of stretch for the grade and size bolt they are working with. They then see how much torque was applied for this amount of stretch. They give a torque value because we don't walk around with bolt stretch gauges in our pockets.
This is why I stated that overtorquing a bolt does more damage than undertorquing does. When you torque a bolt, you stretch it. When you overtorque it, you overstretch it. You actually tear the particles of the bolt apart, which, of course, weakens it drastically.
As far as a loose fastener doing damage goes, if you never check your equipment and overtighten fasteners so you think you don't have to check them, you are setting yourself up for disaster. If you have bolts that frequently come loose, you have a problem. Overtorquing will not solve the problem. This is why, to obtain a cdl, when you do your pre-trip inspection, you are required to physically put your fingers on every nut and bolt on the truck that if that fastener should come loose, would result in a catastrophic failure. They don't say to overtorque it and never check it.
Having been certified as an A+ service technician in my field, I will say that any "mechanic" that torques things down with an air gun or uses overtorquing as a way of problem solving is nothing but a rank amateur and should find a desk job.
