No, this is a running tractor that runs well but had low oil pressure, so I pulled the pan to rebuild oil pump and figured I would change the rod bearings, and in fact they are all worn but evenly. I think it appears to be a good mid life engine. The crank is not scored but has some discolorations and wear patterns typically around the oil hole. I have no time for a rebuild till next winter, and this will be a very lightly used machine. If oil pressure is not restored I will park it till next winter. By the way, changing the rod bearings "engine in place" is tougher than I thought, but just because your on your back and stuff is falling in your face, and you cant rotate the crank fully around due to dangling rods, and so forth. But still doable so far.
