Gale Hawkins
Super Star Member
- Joined
- Sep 20, 2009
- Messages
- 11,815
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Note short change requirement is only for first 2-3 changes so after having almost lost the 5.3Lengine due to no oil pressure due to the known pressure relief valve apparently sticking open potential I am playing it safe until the oil starts staying clear for a couple thousand miles.
Mobil 1 High Mileage synthetic motor oils are especially recommended for high mileage vehicles even those that have used lower quality conventional oils. (see Note 1)
Note 1 -- If your engine has excessive sludge deposits due to less-than-adequate maintenance practices, Mobil 1 High Mileage can help by reducing the sludge left behind in your engine. For severe cases of sludge, ****short oil change intervals (3,000 - 5,000 miles) are recommended for the first two-three oil changes**** as reduction of the sludge takes place. In cases of engine damage that may have resulted from poor maintenance, even Mobil 1 synthetic oil cannot remedy years of neglect.
Oil Change Interval: Oil change intervals can be as short as 3,000 miles or as long 15,000 miles on some new cars. We recommend that you follow the oil and filter change frequencies shown in your owner's manual. With the high-performance reserves of Mobil 1 synthetic motor oil, you can have the confidence to go the full mileage or time frame recommended by the vehicle manufacturer.
