Okay, so I have a theory:
PBY (power beyond) is simply an "extension" in the hydraulic circuit. Because the hydraulic pump on a Yanmar runs continuously, the hydraulic fluid must be able to continually move in and unobstructed circuit (hence, the open-center valve). However, because often times more than one valve (hydraulic component) is desired to be run off the hydraulic circuit, a "power beyond" or extension in this hydraulic circuit is needed (kind of like jumping off receptacle in household wiring).
This being said, from what I can tell the Yanmar hydraulic divider block runs like this.
-High pressure line enters the block.
-Headless plug (which has to be installed) blocks the flow of the traditional In/out ports on the diverter block.
-Pressurized hydraulic fluid is taken from the OUT port on the diverter block (which would typically feed the "IN" port internally if the headless plug wasn't installed) and is routed to our new auxiliary valve "IN" port.
-Because this is an "open-center" valve (the one we're installing to run a hydraulic component) the hydraulic fluid (when not being used by a cylinder or component) must continue to flow (when the valve is in the Neutral position) and therefore, the "OUT" port on our new auxiliary valve is run to the "return oil port/plug" on the side of the transfer case. This, therefore, completes the circuit.
This is all fine and dandy but what about the 3pt system? Did we just "cut in line" and rob the 3pt system of its fluid? I think so! And, here rests the cornerstone of my theory. The manual says we must have a PBY port. And, because we always listen to the manual
we bought the correct auxiliary valve originally
that had a PBY port. But what to do with it?
Remember that original diverter block? We used the "OUT" port to run to the IN port on our new auxiliary valve but now our 3pt hydraulics is starving. So, we take the PBY port on our valve and plumb this back into the "IN" port on our diverter block. Thus, we have essentially "extended" pressurized hydraulic fluid (when not in use by a previously installed valve) to our 3pt system.
This is my theory, anyways. I could completely be wrong. But why else would the manual say we need a BPY port? It's because we're tampering with the diverter block!
For those who simply cut the high pressure hydraulic line prior to reaching the diverter block, (as hoyetractor.com suggests is the easier method) simply installing an open-center valve will suffice. (High pressure line routed to the IN port on the valve and the OUT port routed to the other half of the line you tapped/cut into.
This second (cutting of the high pressure hydraulic line) option is the only way to run a "Pressure Detent" valve I believe, since I'm having such a hard time finding an open-center PBY valve also with a pressure detent.
What do you fellows think about this?
Is the manual way (diverter block) really placing the new auxiliary valve in front of the 3pt system in the hydraulic series? But if so (and the most likely error in my theory, when does the 3pt system recieve this flow of fluid? Certainly not when the new auxiliary valve is in the nuetral position--hydraulic fluid takes the path of least resistance--the fluid would be routed to the reservoir/transfer case. You see my dilemma.
-Thomas
