J_J
Super Star Member
- Joined
- Sep 6, 2003
- Messages
- 18,928
- Location
- JACKSONVILLE, FL
- Tractor
- Power-Trac 1445, KUBOTA B-9200HST
You need PB operation downstream flow to another valve. The only way to get that is with a valve with a PB port. The PB port is necessary to feed the 3pt system. If you are talking about a log splitter valve, those valves are not designed to have a high back pressure. The PB port will handle full system pressure. If you have a standard log splitter valve in series with the 3pt, I would not lift a large load with the 3pt, as it may develop high pressure, and might affect the seals in the log splitter valve.
The only log splitter valve with PB that I know, is the double lever log splitter valve by Prince. Not cheap either.
The OUT flow or RETURN flow on a hyd valve is normally used to pass on the expended fluid from the cyl's, and is not designed for high pressure. Thus the reason for PB.
