MBTRAC
- Joined
- Mar 28, 2012
- Messages
- 391
- Location
- NSW Australia
- Tractor
- Tractors16-600hp Farm & Earthmoving Equip, Trucks etc.
Interesting comparative, the acetone/ATF mix is what I was taught years ago -one of the concoctions passed down by the generations.
A few cautionary notes on the acetone/ATF mix:
1. Don't use/allow the acetone mix near/or to penetrate any seals, bearing or nylox nuts it will destroy them!!
2. Don't use/allow the acetone mix anywhere near paint as it will eaten away!!
3. The mix must be made "fresh" for each use also as the acetone evaporates quickly.
4. Acetone is extremely flammable so don't use near a spark/flame
To remove/preserve any rusted or seized bolts/threads mixed 50/50 Acetone & oil (ideally transmission ATF oil but any oil will work from light machine, compressor, engine oil to the ideal ATF oil) - you won't need much just a few drops applied sparingly, leave for day or so & then retry to loosen the bolt if it doesn't work the first time again put a few drops on each day .....etc until it loosens, above all have patience, it will always work after 1 or maybe few more applications !!! (and will avoid the bolt snapping) - I usualy dip a drinking straw in the 50/50 mix (I make only at max. an ounce or two at a time) then place my thumb on the end on the straw & drip the mix on to the bolt/thread.
It all works very simply as the acetone "eats" the rust/crud then evaporates leaving the oil to progressively penetrate/lubricate the thread (repeated applications allow the mix to work its way into the thread).
Acetone can usually be purchased at any auto or marine store in the paint or fibreglass section.
