MossflowerWoods
Super Member
- Joined
- Aug 12, 2011
- Messages
- 6,067
- Location
- Fredericksburg, VA
- Tractor
- Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Yep....weight is your friend for stability. At one point I did consider hanging suitcase weights or some bar-bell weights on my grinder. Instead....after looking things over.....I eliminated the float on the 3 point draft arms.....took off my PATS EZ change when operating the grinder......and tightened up my sway bars. Doing things like this can help to minimize the sloppy hitch situation.....and thus keep the grinder solidly on the ground.
Still.....sometimes I think about adding a few suitcase weights. Cant hurt. :thumbsup:
Foggy,
I hate to threadjack, but...
I'm still thinking about ways to add weight myself and when I explained it to my dealer, he said to try it...
My swaybars (if I am thinking of the right things are pretty tight. How did you eliminate the float on the 3pt? I do not use a Pat's...
My grinder, when it acts up, typically is below grade and the frame & 3pt twist when I try to sweep, and often similarly if I try to go down it simply lifts the frame and 3pt straight up...
I have a nice heavy (350 to 450 lb weight if only I could think of a way to attach it...
Be well all,
David
