Dmace
Elite Member
The rear facing blade on the box blade and the fact you can turn a rear blade around 180 degrees are for the same purpose. So as you PULL it forward, it smooths the loose soil/sand. NEITHER ARE DESIGNED FOR BACKWARDS USE.For the record...... Thanks dad! Box scraper has a blade on the backside and a blade can be turned around Weird
michaelbisset, I only brought it up in case you were un-aware. I've seen many 3pt arms replaced from the same use and one actually cracked the rear housing which required a $2000 repair plus 4 months of downtime...
For light use at slow speeds, I'm sure it will work just fine. :thumbsup:
