agjones
Platinum Member
- Joined
- May 4, 2010
- Messages
- 590
- Location
- Jessup Mill, NC
- Tractor
- Rk55HC 4n1 fel/bh, Power-Trac 1850, 425d, Terex pt30, Kubota kx033, bx1880, yanmar 8x8 dumper, Magnatrac mh5000 w/ loader, six way blade & backhoe, Dew-eze ATM72LC Slope Mower, Terramite t6 4wd, DR Power brush mower
I've not been shy about my dissatisfaction with the original loud, hot, thirsty robin eh72. And that was before it blew with less than 350 well maintained hours....and subaru failed to stand behind the warranty.
I replaced that unsupported gas guzzler with a thrifty Kubota d662 as an experiment. Verdict : Quieter, cooler, less of a drinking problem. I knew it'd be a little underpowered, plus losing 600 rpm results in reduced hyd flow and there is a hp hit just based on the engine power. It performs admirably. If I reduce the psi to 2000psi it would be a great match.
So with a stand-in machine buying some time, I'm pulling the d662 and replacing it with a d1105 at 25hp & 3000 rpm. Plenty of power. A little less flow. 6.8gpm to the pto by my math, unless you convinced me they used some kind of priority flow in Tazewell....
The new engine, rebuilt and shiny, needs 2" added to the tub rear wall to accommodate radiator and debris screen (lessons learned) no problem, I'd liberated it installing the d662... And the reconfigured engine cover is going to have removable side panels(instead of hinges) as well as bracing to support a rear 3pt lift from redland hill.
The oil cooler is moving, the fuel tank too... And I suspect we will wind up with a braced and shielded vertical exhaust.
If you have made it this far with me, yes I'm posting pics.
QUESTION : if I'm losing flow to the pto from reduced rpm, About a 15%hit, could I increase the relief setting to gain some hyd power? I get the difference between flow and pressure... But if I take fewer bites, can I take bigger ones is my question...
