vrman
hillmower said:The MMM does not attach to rear, just thought that if it would work I would get a rfm. However, due to the fact that everyone who has replied thinks that this could result in serious problems, I will stay away from the adjustment.
I am really just try to find a way to mow faster without paying for a larger tractor. I am probably out of luck.
When you say you want to mow faster, what do you mean?
Do you have such a large area, that you want to get through it faster?
or are you leaving trails of grass behind and have to go over it twice? or ??
If it is just a large area, you can pick up a rear pull offset finishing mower. This would almost double the cutting width. Check out Northern Tool for some pictures.
Otherwise, I'd say cut more often. The less grass you have to cut, height wise, the faster you can go. ie. if you are cutting 4" off the grass, you are going to have to go slow, but if you are only cutting 1/2"-1" you can go a lot faster.
And I'm assuming you are just cutting grass, and that it isn't a field or something where a rotary cutter might be more appropriate.
