ampsucker
Platinum Member
maxfli, if you don't mind me asking, where did you get the giant pump and what is the gpm it's rated for? sounds like just what i need.
amp
amp
ampsucker said:my pressured water will be garden hose in most cases which i already have, so i'm not seeing this as an issue unless i'm missing something???
amp
Amp,
It doesn't work like that. Ignoring frictional losses, if you gear the SPEED up by three, your new TORQUE is 1/3 of the original torque but the HORSEPOWER remains at 17.
With that extra power in mind, you could probably gear it up by 4 or 6 and let your tractor run slower.
John
i think my biggest problem may be in the gearing of the motor. with 540 rpm at max speed on the rear pto and 1,000 on the mid mount, that isn't really close to what a small 5 hp motor spins the shaft at on a regular pressure washer. so, a gear box might be involved. i can see that working. i have about 17 pto hp so a 3:1 gear box would get me 3 times the speed, or around 1620 rpms, at 1/3 the power or around 5 hp at the output shaft considering some gearing losses.
thanks for any help all you build-it-yourself experts can provide!
amp
Yes pressure is important! It's what gets the stuff loose.
Those cheap little pressure washers you see that are getting 1000 to 1500 are using a tiny little tip that makes the pressure but does not put out any GPM (volume), so you have power but in a very small area. This makes work go very slow!
By using a larger GPM ( volume) pump you can use a larger tip which puts out more water at the same or higher pressure resulting in more area covered/ faster work time!
Many companys have used belt drives for years.
Yes you have to cover them and keep the water off!
