Well, I wished I'd read this thread and adjusted the PTO shaft length. I bought a used PHD/Auger. Just assumed that since it had been used that the shaft would be the right length for "any" tractor. I mean, CAT 1 is a standard is it not? Well, apparently the PTO shaft varies in relation to the side and top links in all three directions (dimentions) from make and model to make and model of tractor.
This last weekend, I attempted to pull the PHD coupler from the PTO shaft. I have ended up disassymbling the u-joint using a small gear puller that I had in my truck tool box. (This pushed through the end caps so I knew I ruined the cross. Of course the c-clips were rusted and one broke in place and I had to work the cross out through only one side. First I tried pry bars, but with the tight quarters, I couldn't get real room in there to work them. Then I tried hooking up my 9000 lbs. winch on my truck to pull on the PHD coupler but no luck. I've hammered, squirted WD-40, heated with a propane torch and even tried the small gear puller. Folks, this thing is on there. I'm going to get a bigger gear puller, some PB Rust Blaster and bringing my slide hammer when I go back out there. If that don't work.... I guess its gonna be a grinder with a cut-off wheel? Of course, I tried all this with the PTO shield in place, held up by a bungee cord. But it still got in the way. I'm gonna have to find some good anti seize greese or something for the future.
Any recomendations on anti-seize? I'll report what worked to get this thing off. Hopefully it will only cost a new coupler and not a Tractor repair bill when I get so frustrated to chain the remaining coupler to a tree and throw the tractor in Low range 1st gear and make a crawl for it, hoping not to find my PTO shaft pulled out of the back of my tractor. What a stinking pain that would be....
Regards
