MtnViewRanch
Elite Member, Advertiser
- Joined
- Mar 19, 2005
- Messages
- 10,456
- Tractor
- Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
Brian,
How would my 46hp Bota pull that 7' grader blade in tough conditions? It weighs 5500lbs with the rears filled and FEL. I know a lot of people throughout the country since my line of work is spread all over the place, so you never know when one of my friends is going on a road trip with their pickup truck Probably wouldn't work out, but I'm interested nonetheless.
First off, it would not be a pretty site on the bed of a pickup truck, maybe a trailer, but I know that I would not put it on any of my pickup trucks. Outside dimensions are 90"x96" and around 1400lbs
Well, it would work, but you would have to get use to using it. What so many people do not realize is that to get them to work to there full potential, you do not just drop them and drive away and everything ends up perfect like many people like to indicate. They work best by incorporating the use of the position control the top link and at times the side link. Now since you will soon have all 3 of these you would be all set to be able to get the full potential out of it.
The 7 footer that I use (same size unit that I should sell) with my bigger tractor will stop it cold if I just drop it and drive away. My 7520 weighs in a little over 12,000lbs. But when it is used properly, nooooooooooooo problems. Yes you could make use of it with your tractor. Is it the ideal size for your tractor, probably not. I would think that with any of the industrial use LPGBs (land plane grader blades) that a 6 footer would be better suited for your tractor. But one of the BIG pluses of the LPGBs that I have is that they have a lot longer side runners than all the other commercially built units out there for sale.
