quicksandfarmer
Veteran Member
I don't think a fence unroller is anything special. What would be revolutionary is a machine that tensions the wire to a constant tension as it unrolls it. If you roll out a run and then tension it from the end, if there's anything to hang up on it's hard to get the tension even. You tend to end up with more tension closer to the tensioning spot. If you tensioned it as you went it would be even.
If I'm going to dream, some other ideas:
A machine that plants a t-post with a hydraulic press every ten feet. Like a planter.
A machine that can tie fencing to a t-post.
A machine that can follow a guide wire either laid on the ground or strung from post to post.
A machine that puts it all together: follow a guide wire, roll out tensioned wire, plant a t-post every ten feet, and tie the fence to it, all in one step.
A machine with an alarm when your spool is about to run out.
Woven wire fence with a better way of splicing. With chain link you can weave two pieces together, it would be great to have a woven wire fence that could be easily joined. Maybe something like this:
Wire Panel Connector Hinge - Premier1Supplies
