Hooked_on_HP
Veteran Member
I just looked on Wengers site and their price for a used one is $135 and they don't have one in stock.
Bill
Bill
jerry,
sliding gear and coupling is what you have seen in the diagrams that is hand operated by sliding a fork in an out. On mine I do have an ORC (internal) and sliding gear coupler to activates it. On John Deere they call some of the mechanical operated pto with double clutch "independent" . the difference is the foot pedal is not two stage and separate hand clutch activates the pto. you can check their 5000 series that have that configuration. Pretty much the rest call independent when the main clutch is single. There are two input shafts, inner and outer. the pto shaft is directly splined to the crankshaft so any time engine is on pto is turning. The coupling of this shaft is done by a set of hydraulically activate wet clutch pack. the actuation is done either by a switch to open up a solenoid to provide hyd pressure or by a mechanical arm. the mechanical arm only opens a hyd valve. It is obvious in "independent PTO" a sliding gear would have issue as you can press the clutch all the way and the internal pto shaft keeps on turning.
jc,
The parts list I looked at called it a "clutch" and it appeared to actuated by a lever.
Bill
I got the gear from Messicks on Fri (verry fast) and put every thin back to gether Sat. Today I mowed about 5acres with the finish mower and every thing seems fine:thumbsup:
Bill
Bill
Jc, it has an orc. I had it out and inspected it. They call it a clutch but there is no clutch. It is more like a bearing assembly that rolls freely in one direction and locks in the other like a sprag. I thought about dissambling it to see how it worked but decided against it.
Bill
