leonz
Super Member
As you are looking at things with no financing options:
In my opinion and only my opinion;
It would be worth your while to wander down to Cummings and Bricker in Batavia and look at the small Pronovost snow blowers as obtaining them new is much easier and quicker than the RAD/kubota units in season or out of season.
The smaller rear mount Pronovost PUMA model units(group 1) are built as well as their bigger units and the other farm equipment they make in Quebec.
The PUMA 540 rear mounted blower will work nicely with your tractor as it has a 28 inch cutting height 54 inch cut, a 22 inch diameter 4 impeller fan, the fan housing is nine inches deep, a reduction gear box for the roller chain drive for the cross auger, open cross auger, 4 blade impeller fan, easily replaceable scraper blade, adjustable skid shoes as standard equipment
You can order either a manual rotator or a hydraulic rotator and the semi industrial chute control(Hydraulic control of chute hood) later as an additional item but you would need a pair of rear outlets- 2 set of two.
to be able to use the hydraulic chute rotator and chute control lift and lower function.
I would also buy a can or two of "fluid film" to coat the impeller drum and auger housing which will aid in snow movement and disposal eith the fan.
I would also invest in the (www.clarenceimpellerkit.com) for the 4 blade impeller to increase the snow throwing distance and speed of snow removal.
Yes I was giving a shameless plug for Cummings and Bricker, Pronovost, Fluid Film, Clarences small engines in Michigan.
I was unable to upload the snow blower file as it is too big but I will gladly forward my file to you.
