red flashing alternator light
   / red flashing alternator light
I had replaced the original mechanical voltage regulator with an electronic one about five years ago. 2000 rpm is not high idle but the recommended working rpm for the 23 hp two cylinder diesel so it needs to be charging well at that level. The battery checks 13.09 volts engine off. I'll see what the reading jumps to this week end. I'm also going to take my VOM in and get it checked as it is 25 years old. Thanks
   / red flashing alternator light #22
If the alternator/regulator charged the battery to 13.09 volts then everything is probably ok. That's a good voltage for a fully charged 12v battery, which is a mis-nomer as it is actually a 12.6 volt battery, (6 2.1v cells).
2021 CATERPILLAR D5 LGP HIGH TRACK DOZER (A60429)
2021 CATERPILLAR...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2022 KOMATSU D71PXI-24 CRAWLER DOZER (A60429)
2022 KOMATSU...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere 1025R (A53317)
John Deere 1025R...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
